    Question stripping kitchen cabinets
    our tired cabinets and near by book cases have cracked and peeling varnish on them. I have tried many non toxic products to strip this off, no results, when I asked 2 of our large Home repair stores they say the only way is to use toxic highly flamable products and never in closed areas, it's winter and I don't like those, is there a safe clean smelling product available? The eating bar under the top is quite large and will require alot of work to get all this varnish off. HELP
    Mar 2011
    18
    Default Re: stripping kitchen cabinets
    Have you called the manufacturers of the nontoxic strippers? I would ask them what's going on--why didn't they work, and is there anything they would suggest to make it work better.
    A friend of mine used a soy-based stripper to remove the hideous pink paint a previous owner put on his Victorian mantelpiece. I can ask him for the brand name if you want. What products have you already tried?
    Apr 2011
    10
    Use varnish & stain stripper it is quicker make sure you lay plastic down.
    Apr 2011
    11
    I have circumvented this problem by stripping very small areas at a time. It takes longer, but you avoid the dust and health hazards generated by sanding. So, try doing 2 sq.ft. at a time wearing a mask, chemical-resistant gloves, and goggles. Put on a sweater and open the windows. The good news is that toxic strippers evaporate very quickly so there are no lingering fumes/smells like with paint.
    By the way, I have documented my adventures with paint stripper at my blog: fiftieskitchenredo.blogspot.com.
    Good luck!
