    Default Name of Sand for Walkway Fill
    I recently saw an episode where a patio was re-leveled and a particular type of sand was used for crack fill. However, I failed to write it down. It was poly something. I need to repair my walkway and would like to use this sand. Anybody know the name of it?
    Aug 2009
    Ladson,SC
    192
    Default Re: Name of Sand for Walkway Fill
    It may have been Joint Lock Polymeric?
    Oct 2010
    6
    Hey JackiK, HDNewf here from The Home Depot out of Chicago.
    I think this is what you are looking for:
    This Oldcastle 40 lb. Paver Joint Sand is a sweep-in joint sand enhanced with polymers that hardens with moisture, so it won't wash out like regular sand. It reduces weed growth and resists insect penetration in joints of pavers, bricks and flagstone up to 3/8 in.
    * Use to fill joints between pavers, brick and sandstone up to 3/8 in.
    * Use to block weed growth in paver joints
    * Easy to apply by sweeping into joints
    * Enhanced with polymers to lock sand into place and resist washout
    * Resists insect penetration for long-lasting use
    I hope this helps,
    HDNewf
    Both of you are awesome! Thanks.
    12
    shin and xing both are best for it
    just try once
