    Feb 2009
    Default brick molding gap
    installing brick molding with voids in the wall where it leaves gaps along the top of molding, whats the best answer to cover the gaps ? is caulk the way to go
    5,797
    Default Re: brick molding gap
    Caulk is the normal solution. Make sure it's a paintable caulk not silicon.
