    Nov 2010
    Default Vinyl tile floor, humidity question, sub-floor, etc
    Long story short, just bought an older home. With many additions, there is a partial basement and a few crawl spaces that are exposed dirt under additions that are about 3-4 feet tall. I am looking to install vinyl tile in the kitchen, but it is over one of the crawl spaces that has an exposed dirt surface. The humidity in the house was over 80% before we started running a dehumidifier in the kitchen.
    I plan on sealing the crawlspaces with vaporlock 20 in the future, but do I need to do that before installing the vinyl tile. Will the high humidity from the crawlspace wick through the floor and weaken the adhesive?
    Also, using a water resistant treated sub-floor like:
    http://www.homedepot.com/Lumber-Comp...atalogId=10053
    Will I still need to prime the floor, or is the water resistant treatment good enough.
    thanks in advance for any advice.
    Default Re: Vinyl tile floor, humidity question, sub-floor, etc
    The dirt floor in the crawl space should be covered with a vapour barrier -- 6mil poly. This will greatly reduce moisture issues with the structure above.
