Results 1 to 8 of 8
    Nov 2010
    Denver, CO
    Default New fence post holes off line.
    All:
    Using a two-man gas-*****ed auger, a friend of mine and I drilled a line of fence post holes. I could swear we had a string line in place, but the resultant fence line is significantly arced from one end to the other. The holes are far enough off from straight to be noticeable, but close enough to where they should be that drilling new holes in the proper locations would be difficult if not impossible.
    How do I fix this?
    Thanks for all your help,
    Fencely A. Doofus
    8,002
    Default Re: New fence post holes off line.
    Get yourself a pair of clam shell and align the holes manually. Rerun the string for reference.
    1,890
    Spruce, is that your wife's good sheet in the background?
    8,002
    I thought it was yours ...
    Nov 2010
    Denver, CO
    Spruce:
    That's what I was afraid you were gonna say.
    Thanks.
    RJS
    8,002
    Quote Originally Posted by RocketJSquirrel View Post
    Spruce:
    Thanks.
    RJS
    Once you've got the main hole, truing it up with clam shells is a breeze, even if it's hard pan. Actually, if it's hard pan, you're better off with a spud bar to do the digging and the clams to remove the dirt.
    Spud bar:
    Nov 2010
    Denver, CO
    Smile Re: New fence post holes off line.
    Spud bar:
    Spruce:
    Sorry for the delayed response. I've been busy (re-)digging holes.
    Yes, the combo of a clamshell set, spud bar, spade, mason's line, and water for weakening the resolve of our recalcitrant clay did the trick. Thanks for your help.
    RJ Squirrel
    8,002
    You're welcome,
