    Nov 2010
    5
    Exclamation Lining Drain Pipe technology
    We have a leaking drain pipe from top of flat top roof of duplex from the 30ies. It leaks into the basement (around the visible part of drainpipe) when it rains and also when we take showers on 2nd floot (the 1st floor drains into a separate drain so is unaffected). We also noticed sewer smell in 2nd floor bathroom a while ago.
    So all the plumbers here seem to want to do is break down walls (with vintage ceramics!) and ceilings to replace the main drain pipe or drain stack from roof to basement. At a major cost and inconvenience. Cast iron 4". We are trying to find a good pipe lining service that does the job locally but are having no luck - saw that Maxliner was featured on an old episode - can anyone point us to a good company that provides this service or similar on vertical drainage pipes using epoxy or similar (factoring in that we have to allow an area for the drains of the bathroom fixtures to connect to main drain)
    thanks!
    Dec 2009
    40
    Default Re: Lining Drain Pipe technology
    Listen to the professionals.Pipe lining will cost you just as much and you still have to do the tie ins manually.
    Nov 2010
    5
    thanks for the feedback - what do you mean by having to do the tie-ins manually?
    Dec 2009
    40
    The areas where other drains connect to the main drain.
    Nov 2010
    5
    Yes, I understand that - the idea would be to line the vertical sections above the tie ins to roof and below the tie ins to basement (only the 2nd floor has tie-ins to drain)- why could this not be done - with an opening at basement and the vent stack at top, if the area of tie-ins is well mapped, then why could we not line below to bottom and above to top? thanks for any additional insight people!
