    Nov 2010
    Default "medium" insulation
    Hi,
    I have a 1951 Cape Cod and it is insulated with insulation that says "medium" on it. I assume it is original because the whole house is insulated with it (walls/attic). Does anyone have a guess as to what it's R-value would be?
    Nov 2009
    71
    Default Re: "medium" insulation
    What is the material and thickness? You can probably then find the R value on the EPA.GOV site.
    Nov 2010
    Thanks! It is fiberglass rolled insulation. About 2 inches thick so I guess about R6-8.
    nova scotia, canada
    1,522
    that sounds about right greg give or take 1-r
