    Sep 2007
    Default Want to remove utility sink
    We have an old utility sink in our (main floor) laundry room and we'd like to remove it to install a cabinet instead. Question -- where will the washing machine drain into, if we no longer have the sink? We have septic, and a sump pump in basement. Does this kind of job require a plumber? Just wanting to understand the logistics. Thanks.
    Christy in NJ
    6,115
    Default Re: Want to remove utility sink
    The drain is still there so install a stand pipe hooked to the drain. If it is feeding into the septic make sure you use septic safe laundry detergent.
