Thread: plumbing vent
    126
    Default plumbing vent
    Apparently my plumbing vent may have come detached and is causing the leak in the roof. I have put a cap on the plumbing vent and there is no more apparent leak. Which plumbing vent cap is best and should I still have this vent repaired on a flat roof of course and is there a way the repair is done without breaking the ceiling.
    1,418
    Default Re: plumbing vent
    It's probably the flashing -- known as a "roof jack" -- around the vent pipe.
    Unfortunately, the materials and methods for working on flat roofs aren't very friendly to the do-it-yourselfer. Your best bet is probably having a roofer come out and fix it.
    P.S. -- Plumbers aren't qualified to fix roof leaks. I should know: I was a plumber once.
