    Nov 2010
    Default Furnace Transition to Duct Work Sealing?
    We have a forced air furnace. The "collar" that transitions the furnace to the duct work is flexible (due to the expanding soils in Colorado). The collar has some holes in it. I have used duct tape to seal the holes, but it doesn't stand up to the heat. What else can I use?
    I would appreciate any ideas or product suggestions.
    Thanks,
    Laura
    565
    Default Re: Furnace Transition to Duct Work Sealing?
    Laura,
    Check the Yellow Pages under "Furnaces-Supplies & Parts" or "Sheet Metal Products", or "Heating Equipment Parts-Wholesale"
    They carry Aluminum Foil Tape in 60 ft. rolls rated at 275 degrees for approx $15, or Metalized Duct Tape in 60 yd rolls rated at 200 degrees for $7-10.
    You can also buy a tube of High Temp caulking compound (metal standard caulking applicator needed) for $10 with which you can attach heavy duty aluminum foil to holes in Plenum or ducts.
    Thin pieces of duct sheet metal (Home Depot/Lowe's) can be cut to shape with a sheet metal shears; small holes drilled, & easily attached to flex plenum/duct with self-tapping sheet metal screws.
    The entire piece of plenum flexduct can be removed & replaced with a new piece, available at the above wholesale dealers---many wholesale dealers will sell to homeowners, either on the web or in your local town, often at wholesale prices---known as a "cash sale".
    Google "Plenum flexduct", or "flexible duct installation", or "metal heating duct products" or "flexible heating duct products" to get a ballpark price range for these products.
