Results 1 to 9 of 9
    1,387
    Default drip flashing below the window
    Howdy installing a bunch of windows am using "Z" flashing above the windows but cannot come up with an idea how to flash below the windows. Some are wood aluminum clad, some wood, some no jamb plastic . Anyone have any ideas? Installing them with new cement siding and to make it more interesting also in rain screen walls.
    1,522
    Default Re: drip flashing below the window
    try using either 4" blueskin or vycor. are any of them being replaced, if so do a drip pan on the sils before the new windows go in
    1,387
    Hi J Kirk- thanks for the suggestion all the windows are being replaced and have installed some with window wrap water proofing. What do you mean by drip pan?
    Aug 2009
    Ladson,SC
    192
    Look at JamsillGuard this drawing will explain.
    1,522
    basically using 6" vycor/blueskin you run it along the rough sil so its 3" on the sil and 3" down the wall yet wraps up the side of the r.o by 4". any sweat that forms on the window will hit the membrane instead of soaking into the framing and rotting it
    finehomebuilding.com has a video on it
    1,387
    Hi thanks i did install the window wrap membrane as had researched how to make the rough opening water tight on several web pages. The method i used is as you suggested . But my question is for a metal flashing that would be installed so water cannot enter below the window and entry behiend the wall siding. I do not think it exists but thought it would be a great item for someone to market...
    1,387
    Quote Originally Posted by Hank Bauer View Post
    Hi thanks the product is one i will use in the future.
    1,522
    in regards to under... we make a metal drip pan for doors. as there is no overlap via nailing flange on the sil of a door.. not only that but some membranes arent compatible with siding caulking...
    1,387
    Thanks again J Kirk. I hope the caulking i have been using is not one of them. Looks like i will have to experiment and crate a flashing.
