    Feb 2009
    Default How to insulate floor over crawlspace in a remodel
    I am tearing out a floor that is over a crawlspace (a tiny one at that) and when I frame things back I want to insulate the floor.
    If I recall from my teachings, the vapor barrier needs to be to the heated side, so couldnt I use a faced R30 placed in the floor joists from the top and then lay sub floor over it?
    Thanks
    Kyle
    1,387
    Default Re: How to insulate floor over crawlspace in a remodel
    Howdy, do not use faced insulation instead use R22 fiberglass with no vapor barrier as it will not trap moisture. To keep mine from falling down i staplet the pink survey string across the joists about every 3 feet. worked real good.
