Results 1 to 10 of 19
    Feb 2009
    5
    Default broken light buls still in the fixture
    When I moved into my home, there are several bulbs broken in the fixtures. It is safe for me to take them out with a pair of pliers if the light switch is off???
    Thank You for your replies.
    1,962
    Default Re: broken light buls still in the fixture
    The power should be turned off at the breaker, not just the switch.
    5,987
    As Ed says turn the breaker off. I have seen to many times where the switch was in the neutral line rather than the hot.
    1,845
    I've heard that an old tennis ball works pretty good for removing broken light bulbs. Cut a small hole in the ball to go over the stem of the bulb. Or maybe it was a small rubber ball.
    I concur with turning off the breaker. Since you can't be sure which breaker it is, turn off the main.
    Feb 2009
    5
    Great idea with the tennis ball tya vm
    Feb 2009
    5
    tya for your help. I don't have a main switch to my breaker but i'll just shut them all off until the job is done. LOL
    Feb 2009
    5
    Wink Re: broken light buls still in the fixture
    tya vm for the help
    near St. Paul, MN
    166
    I've also used a trick where you push a chunk of potato into the socket. (You have to trim the potato to the right size to fit into the socket.) The broken shards of the light bulb get imbedded in the potato and then you can unscrew it. Just don't eat the potato when you are done with it! (And like the others said - make sure the breaker is off.)
    Shamokin, Pa.
    645
    I just use a good pair of needlenose And a dose of careful as well.
    7,815
    With gloves and safety glasses.
    Did anyone mention to turn off the breaker?
