Results 1 to 10 of 10
    Nov 2010
    Question Correct Orientation of a Ball Valve?
    When installing a ball valve, should the handle of the open valve be over the "supply" side pipe or over the down stream pipe? I presume there's a convention (accepted standard) and hope someone can tell me what it is.
    Regards.
    Default Re: Correct Orientation of a Ball Valve?
    With the handle inline with the pipe, the valve should be in the "on" position. When the handle is at a right angle to the pipe it should be in the "off" position. This is how the valve should have been set up from the manufacturer, if this is not the case with your valve, then it's likely been tampered with and should be replace with a new valve.
    Dec 2009
    40
    the open position can face either the supply side or down stream direction but handle should have enough room to be fully on or off.
    Dec 2008
    Midwest
    174
    There is no direction of a ball valve. i usually postion it so when it is off the words are right side up and can be read.
    1,906
    Spruce, you misread the question. The question was whether or not a ball valve has an "inlet" and an "outlet" side like a globe valve or angle stop has. The answer, as others have posted, is that it can be installed in either direction.
    That said, I kind of like to orient it so the handle is pointing in the direction of flow, unless clearance is an issue.
    Hey, we could start another debate, just like whether it's better to put the ground pin up or down on a receptacle outlet!
    Dec 2016
    I have to replace a 70-year-old globe valve that is now completely useless (i.e., don't close) in the water inlet to the house. Also, another one on a line to an outside outlet. It is copper pipe. I am installing ball valves and questioned the orientation, hence, reading this string. The posts have been most educational.
    My take: Both ball valves I purchased (3/4 inch and 1/2 inch) have a "relief" port (my description) to the side, which has a small, threaded, knob to close the port. It is on the side of the valve that the handle points to when in the open position. Looking at the current globe valves, all of which have the same relief port (70 years ago!), the port is on the discharge side of the globe valve. My surmise is that, after closing the inlet source, this relief valve allows pressure relief and water draining to do maintenance downstream.
    So, I am going to install the globe valves with the relief port to the downstream side, which also coincides with the orientation of the handle (downstream) when in the open position.
    Maryland
    2,009
    The ground pin goes down. No reason. That's just the way it's usually done in my neck of the woods
    6,097
    Quote Originally Posted by jdwhiteii View Post
    You are correct, any valve with a pressure relief should be installed so the relief is on the output side.
