    145
    Default outdoor lamppost
    My lamppost goes on at night automatically. Now I see the little magic-eye has become pushed into the lamp post and water may seep in. Is there a way to fix this or must the complete lamppost be replaced.
    Thank you
    Oct 2010
    Default Re: outdoor lamppost
    Not sure what type of post you have, but most I have worked on the eye is replacable. The ones I have replaced is accessable by taking the light of completly and redoing the photo eye. Caution should be taken when doing this because the wires will be energized. Start by turning off the ***** to the light. Then take the light off of the top of the post, then you sould be able to access the area of the photo eye. I will check back here in a couple of days to see if you have any other problems.
