Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    MN
    455
    Default Re: wall insulation in old home?
    So you do have insulation in the attic,some confusion in terms.
    This is what most folks normally consider as insulation in the attic.
  2. #12
    Feb 2009
    I have a 1920's house and have removed the lathe and plaster in an upstairs bedroom to get rid of some scarey electricity and insulate. I have a cotton insultation. Question is do I put a vapor barrier-visquin (Sp?) between the insulation and the outer wall and do I put something on the inside wall of the insulation under the sheet rock.???
    Help
    ana
  3. #13
    Feb 2009
    Yes, I already have insulation in the attic, although not enough yet since I haven't gotten all the knob and tube out of there. The question is about walls.
    ana
  4. #14
    MN
    455
    If you live in an area with cold winters the vapor barrier only goes on the warm side.
