    Feb 2009
    Default hot water running out to quick need help
    I have been having a problem with my hot water. I run out after 2 showers of a total 20 minutes from a 50 gallon hwt with 30 to 40 minutes of recovery time in between. I have replaced both upper and lower elements, thermostats and have also replaced tank all together thnks to warrenty I have been told I have a problem with "crossover bleeding" I have replaced 2 faucets and a single handle faucet valve and this is still having the problem. need help
    1,131
    Default Re: hot water running out to quick need help
    Hmmmmmmmm. If you have replaced the WH and these other faucets.....I have to ask if you have a "Y" blender hose thingie anywhere in the house that has a hose with nozzle or similar attached. ??? If so....are both the hot and cold open to this device?
    Have you tried closing off the supply valves to your clothes-washer?
    Any chance that you have a single handle shower/tub control that hasn't been replaced?
    Any new installed plumbing in the house? (I suspect not or you would have mentioned it)
    6,115
    Quote Originally Posted by doitself View Post
    Even with a water saver shower-head you would use nearly 40 gals of water in 20 minutes even more with a standard shower-head. Could be you should consider a tank-less water heater.
    1,131
    Or maybe turn up the temp on the WH so less hot water is being used during the blend.
    Or..........maybe there's a balancing valve inside the shower control and it is malfunctioning. ????
