Results 1 to 8 of 8
    Oct 2010
    Default Installing Wainscoting
    Does anyone have any ideas as to how to treat a heat/air return when installing wainscoting?
    Thanks!
    7,190
    Default Re: Installing Wainscoting
    More info please. What kind of wainscot, what color of wainscot, how large of AC grill, where is it located?
    Oct 2010
    - Raised panel
    - Oak
    - located on wall, above baseboard
    - Return is 22 1/2 inches by 30 1/2 inches
    - Return has hinged doors, lourves, with filter
    Husband will build the panels.
    Thanks!
    7,190
    Is the grill high enough to be centered in the raised panel? If not, can it be raised up?
    When the layout for the wainscot is done, start by centering a panel over the grill and work outwards from it, that way you're providing the best possible aesthetic location for the grill. If the grill is not properly positioned to work within a raised panel, the leave the area with the grill as a flat panel and let everything else be raised. Paint the grill the same color as the finished wainscot will be to blend it in as much as possible.
    While expensive, the grill could be relocated to another area of the house.
    Oct 2010
    Thank you so much for your ideas.
    My plan was to gather info and present to husband - hilarious because when I told him what I was doing, he told me he had a plan - it was the same as yours!!!
    7,190
    You're welcome. Post back with progress and pictures.
    Quote Originally Posted by bama52 View Post
    - Raised panel
    - Oak
    Thanks!
    Feb 2011
    10
    Panelling is a wall covering constructed from rigid or semi-rigid components. These are traditionally interlocking wood, but could be plastic or other materials.
