Thread: dryer vent
    Feb 2009
    Default dryer vent
    I have a long dryer vent (27') from dryer to outside wall, Can I use a solid pvc pipe instead of using the sections of aluminum pipe that you normally see.
    6,080
    Default Re: dryer vent
    Not if it is a gas dryer. You should check locale requirements for max. run lenth also.
    Oct 2008
    14
    You should be using rigid aluminum or steel ducting and the appropriate length depends on how many 90 degree turns you have. Obviously the shortest most direct route is the best way. You should not be using PVC.
    Check out this link for detailed information:
    http://www.appliance411.com/faq/dryer-vent-length.shtml
