Results 1 to 1 of 1
    Feb 2009
    Exclamation Broken water pipe
    I received my water bill and I was shocked. I usually use 2000-4000 Gals a moth. My bill was for 79000 Gals.
    I checked every sink and pathroom and there was nothing leaking. I went to the meter and it was spinning. I turned off the water at the valve I added a few years ago at the start of the slab. It stoped.
    I did not feel the floor being hot. The Hot water pipe from the WH is not hot so I must be the cold water.
    How can I repair this?
    The house was built in the 60s. I was told it prob has galvnized pipe. Do I repipe with PVC over the attic?
