Thread: Copper pipe
    Nov 2009
    Default Copper pipe
    What type of copper tubing is better for a house with well water Type L or Type M.
    South*East
    1,208
    Default Re: Copper pipe
    Type L is better. Way back when, it was required by most building codes. Still is in some areas. Type M was used on heat. If cost is not a problem I would go with L.
    John
    1,146
    Type L is fully adequate for domestic water supply. For heat supplies, I would want to use type K, which has wall thicknesses typically 20% greater. Type M is thin-wall, and is for flare-type connections, AFAIK.
    S_M
    South*East
    1,208
    Quote Originally Posted by Sombreuil_mongrel View Post
    S_M
    You have it backwards. Type K is typically used for under ground. If you tried to flare type M it would split the pipe. Type M is used on heat as you are only working with 12 to 15 lbs.
    John
