    Sep 2007
    Default Tile on my covered deck?
    I am replacing my deck with a covered deck / screened porch. My wife wants to put down 2x6 boards then backer cement board as an underlayment for tile. Is this adviseable? I live in the midwest and we have all 4 seasons which will result in a lot of expansion and contraction going on. Thanks!
    Sep 2007
    Long Island, NY
    269
    Default Re: Tile on my covered deck?
    2x6 boards?? You mean floor joists? And why only 2x6's?? Whats there now?
    If you're going to tile the floor you have to be SURE there's no deflection in the floor which means using the appropriate sized floor joists for the span you have and also you should have TWO layers of WOOD subloor totaling a minimum of 1 1/4" thick and then you have to THINSET and screw down your CBU (cement boards).
    OR instead of cement boards what I'd use in your case would be a product called DITRA. I'm enclosing a link for you as to where you can get it on line and they also have the installation PDF for you to look at.
    I'd go this route rather than a cbu.Its a little more money than CBU's but its easier to install anddddddddd its better.
    http://www.tileprotection.com/search.php?mode=search
    Be well
    andy
    Hidden Content
    ॐשָׁלו
