    Feb 2009
    Default Tucking Carpet Against Adjoining Tile Floor
    How do I finish off a carpet edge that adjoins a tiled floor area. The tiles are 1 ft. square and the carpet is 17 ft. wide against the tiled area.
    Default Re: Tucking Carpet Against Adjoining Tile Floor
    The easiest and probably most common method is with a metal transition strip that is nailed into place. I personally don't care for that look and would rather "tuck" the carpet at the transition point. A tuck is done by installing a Z-bar flashing along the carpet edge. The carpet is stretched, then tucked under the flashing that is then tapped down with a hammer to bind the edge down along the tile, resulting in a "seamless" transition.
    With a rubber hammer. Here's a link to Homedepots transition strips http://www.homedepot.com/webapp/wcs/...atalogId=10053
