    Default Under Sink issues
    I noticed yesterday that my sink drain was not connected to the tailpipe. After many tries, I was able to screw it back together (see picture). That no longer seems to be an issue. However, it's not on very tight; does the tail pipe need to be replaced with a plastic slipnut?
    Also, see the other attached pic. Water is also leaking from the drain itself. You can see a drop. Does this mean I need a new drain?
    This work was done by plumbers who screwed up many things in my house. Let me know if it looks like bad work.
    thank you
ID:	2073   Click image for larger version.
    5,796
    Default Re: Under Sink issues
    The leak will probably be taken care of if you tighten the basket collar. Do you have a nylon compression ring under the nut?
