Thread: Tapcon Trouble
    Oct 2010
    Default Tapcon Trouble
    I have attempted on multiple ocassions to drive my tapcon screws into the masonry block of my window sill ledges, but have been unsuccessful. Everytime I try to drive the screw in, I hit what seems like a piece of metal. My house is a 1950's colonial made with concrete/cement block and aluminum siding. I'm not sure if there is a piece of siding behind the block or if I'm hitting some other material used to "fill in" the block. Any advice on how to drive these screws in,so that I can finally hang my window boxes would be greatly appreciated.
    nova scotia, canada
    1,522
    Default Re: Tapcon Trouble
    your hitting either rebar or aggregate
    simply move the location of the screw, or try a different length screw
    Typically the pre-drilled hole should be deeper than the screw is long.
    Which should mean the drill bit would hit something rather than the screw.
