Results 1 to 7 of 7
    Jan 2009
    Default Why space at top of crown?
    In many older home I have seen crown molding installed with a narrow gap between the crown and the ceiling. It was done deliberately because the gap is uniform. Why is it there? I have a couple theories but would like an educated answer if someone has it. Could settling/separation problems be counteracted by leaving the gap? Or is it just a design idea?
    7,592
    Default Re: Why space at top of crown?
    In days of old, a "picture rail" was installed with a gap from the ceiling, from which pictures were hung. I've seen the gap anywhere from the top of a door jamb to within 1" of the ceiling.
    Jan 2009
    A. Spruce, thanks for the thought and picture. Looks like that is the reason for the gap. Makes sense since older home were usually full 3/4" plaster which makes driving nails for pictures pretty tough and eliminates the holes left in the wall when you move the picturs.
    Hugh
    Eden, NC
    285
    Good answer A.Spruce, I never knew that information. I keep learning more and more from these threads.
    Calcats
    7,592
    Glad to have helped.
    Oct 2008
    Kansas City, Missouri
    126
    Now get over here and help me!
    http://advice.thisoldhouse.com/showthread.php?t=10817
    7,592
    Quote Originally Posted by KCPumpkinStalker View Post
    I would, but it's gonna cost ya!
