    Jan 2009
    Buffalo, NY
    34
    Default floor tile problem
    I am trying to tile over a hardwood floor (wife's idea) but the tile cement is not sticking to the floor. I'm guessing I have to sand off the polyurathene to get the cement to stick. Wants it done by the weekend!
    Jan 2009
    Buffalo, NY
    34
    Unhappy Re: floor tile problem
    Anyone have any ideas? I need help on this one.
    7,914
    Default Re: floor tile problem
    Thinset won't work in this application, you'll have to use a mastic (glue ) for tile. It should also be noted that if there's any movement in the wood, the tile will crack and pop loose as well.
    1,131
    Don't even try laying ceramic tile over a hardwood floor without first & properly .....installing an appropriate underlayment.
    Also.....have you checked whether the deflection will even allow for ceramic tile?
    http://www.johnbridge.com/vbulletin/deflecto.pl
    Jan 2009
    Buffalo, NY
    34
    Thanks guys. I saw that website posted earlier and that part is fine. great ideas and will give them a try will report in a few days!
    Sep 2007
    Long Island, NY
    269
    Quote Originally Posted by jboller56 View Post
    My guess is your hardwood floor is 3/4" over a 3/4" subfloor which should make any deflection in the floor a non issue as long as the HW floor is nailed down solid with no buckeling in it.. If it were me I'd go over the poly'd HW floor with a 60 grit sandpaper in either a belt sander or any electric sander you have just to scuff it up real good and get any loose stuff off then I'd thinset down some 1/4" hardiebacker screwed into the floor below but that may be a drag of a job screwing into an oak floor in which case I'd buy Ditra and just thinset that down then get to tiling. MAtter of fact...forget screwing down a CBU...just buy a roll or how ever much you need of Ditra. Way easier and even better....justa bit more in materials but a whole lot less in labor...
    You can pick up rolls of Ditra in the tile dept of HD.
    Hidden Content
    ॐשָׁלו
