    Jan 2009
    Default Insulate block walls
    I have a stone house behind the sheet rock walls there is no insulation.What would be the best way to insulate the walls without using 2x 4s.Could I you 3/4 insulation board with 1/3 boards then put up the new sheet rock?
    Thank you
    San Diego, CA
    367
    Default Re: Insulate block walls
    Yes that would work.
    Good Luck.
    Jan 2009
    Thank you for information
