    Jan 2009
    Cambridge, MA
    Default radiator (steam heat) smells sweet-ish
    We live in a typical tree level building in Cambridge, MA. We are on the second level. Most of our steam heat radiators work well, but one clangs A LOT, and recently seems to be emitting a sweet scent...and maybe even a little steam. Does anyone know what this is? Who would I call about this? A plumber?
    Jan 2009
    Taxachusetts
    136
    Default Re: radiator (steam heat) smells sweet-ish
    Most of time bangs and clangs in a steam system can be traced to one of three things. 1. A closed, clogged or faulty air vent (which should only be releasing air not steam), the air vent is the silvery colored usually d-battery shape/size threaded 1/2 to 2/3 up the side of the radiator.
    2. A closed, or partially closed radiator shut-off. Located between the steam pipe coming through the floor and the radiator itself.
    3.Incorrectly pitched radiators or the steam pipes that feed them. Everything should be slightly pitched back to the boiler so the water can return once the steam condenses.
    Hope this helps. A plumber with steam experience (I'd hate to say old-timer) would be your best bet. The smell is probably the old boiler water coming through as the steam leak
