    Jan 2009
    Default hot water circulating pumps
    Does anyone have experience with installing circulating pumps to get hot water to distant sinks?
    Jan 2009
    Arlington, Texas
    Default Re: hot water circulating pumps
    Hi my friend, that is more or less my question about a hot water adapter. On a past show a woman home owner had the same problem. The device I saw installed spliced into the hot water line under the sink and was wired into an outlet. When the water was turned on a sensor read the temp. and would heat the water until the water from the tank reached it. My problem is I don't know what it's called or where to look for it.
    1,846
    One particular brand is the Laing Autocirc pump.
    www.autocirc.com
    Jan 2009
    Arlington, Texas
    To Fencepost
    Thank you for the information on the Laing Autocirc. Pump. Just what I was looking for.
