Results 1 to 10 of 11
Thread: New invention?
    5,558
    Default New invention?
    Has anyone tried these? http://www.spring-bolt.com
    6,481
    Default Re: New invention?
    Looks interesting. Wonder how well they really work.
    5,558
    That's why I asked.
    jack
    6,481
    Makes ya wanna get back in the game to find out, doesn't it?
    Oct 2010
    Baltimore, MD
    17
    "Spring-Bolt (patent pending) replaces traditional handrail-bolts."
    Key words: fasteners, tension coil spring, clamping pressure, steel pin
    So, how do these fasteners work? To find out, I perused Spring-Bolt's website (www.spring-bolt.com), carefully watched their instructional videos, researched the pending patent (www.uspto.gov), and I spoke to the inventor (Roger Rock of Rock Lock Fastening Systems, Inc). Voila! They work something like this: Essentially, the mechanical energy required to provide clamping pressure is accomplished by reverse-threading two opposing tension coil springs, and the system's lateral strength is maintained by a concentrically placed tempered stainless steel pin. In other words, after the post or handrail receiving holes have been drilled, and the left and right handed springs have been screwed (anchored) into their respective holes, a metal pin (which helps to guide the springs) is inserted into one of the springs, the opposing spring (which is screwed inside of the other handrail) is then slid over the other end of the pin. After the ends of the two springs make contact, they are twisted together. Twisting, or reverse-threading, the springs causes a shorting of the combined initial spring length. After several more twist, the wooden handrail ends make contact, thereby fixing the system's operational length. A few more twist cause the springs to elongate, but tensile strength (resistance to elongation) tightly pull together the handrails, and thus provide the required clamping pressure. I know, reading the description was a bit stressful, and by now you are somewhat strained. But read it again, and then re-watch the videos.
    Hidden Content // Editor-in-chief
    5,558
    Bruce we can all read, the question was has anyone tried them.
    1,522
    the reply reminds me of a certain someone
    Oct 2010
    Baltimore, MD
    17
    Since 2007, approximately one-hundred-seven other TOH readers have apparently viewed this thread, and likely everyone in the larger audience was not a certified carpenter. Hence, for the benefit of new viewers, the reply-in-question provides an immediate, comprehensive and convenient product description, and for others, it might support conceptualization and learning. Moreover, I encourage senior discussion members and journeymen craftsmen to obtain a Spring-Bolt, evaluate it, and post their expert opinion. Jack and others are still waiting. Bruce
    Oct 2010
    I work for a company called CP Stairmasters in Halifax, Nova Scotia, Canada, which supplies and promotes Spring Bolt fasteners. We have used the product in commercial applications. I also have several stair installers / renovators who use it on a regular basis.
    I'd be happy to answer any specific questions you might have about use of the product.
    Oct 2010
    This is a great product that I use. My company builds stairs in South Florida Boca, Palm Beach, Jupiter Island , high end customers who don't want to see nail holes and plugs. You still want to use glue or epoxy with the Spring Bolt.
    M & M Stairs
    West Palm Beach, Fl
