    Jan 2009
    9
    Default looking for basic wiring diagrams
    Does anyone know if there is a web site that has good wiring diagrams for beginners. Every where I looked the diagrams are to complex. I'm just trying to wire switches to a pull chain light. Thanks!
    Jerry
    Default Re: looking for basic wiring diagrams
    I can't direct you to a website, but I can direct you towards an excellent wiring book. Go to Amazon.com and look for "Wiring Simplified". It is a technical manual, written in layman's terms, based on the latest electrical codes. Not only is the writing easily understood, there are ample diagrams and pictures to help you along as well.
    The next best thing would be to post here what you're looking to accomplish and the many fine, experienced, tradesmen that populate this site will put in their advice.
    Jan 2009
    9
    Thanks A Spruce,
    I'll try that!
    612
    A quick search led me here, try this link. There are examples for other scenarios also.
    http://www.electrical-******.com/bas...variation1.htm
    Hope this helps. Hit the breaker before starting!!
    1,387
    Howdy, consider a trip to your library wiring books are available.
    Ma
    9
    If the wiring diagrams are too complex maybe the task at hand is out of your knowledge range..I'm an electrician and if I can't easily follow the diagrams at hand I try to visualize what I'm trying to accomplish with the circuitry.
