Thread: hot plug
    May 2010
    49
    Default hot plug
    whenever wife runs vacuum cleaner for about 10 minutes, the prongs on the plug get hot. the cord itself does not heat up. this happens all through the house, not just at one outlet, and no other plugs or cords heat up.
    is this normal, or should i be concerened about this?
    note: cord was run over once - sheathing was torn up a little, maybe a nick or two on insulstion on individual wires inside. i wrapped each wire with vinyl electrical tape & the wrapped entire cord at that area.
    should i think about replacing the cord?
    thanks
    5,805
    Default Re: hot plug
    You probably have broken strands inside the plug. Either cut the plug off and install a new plug or a whole new cord.
