    Jan 2009
    Default Toilet bowl will not hold water
    I was away from my home for three months and when I returned, I noticed the water in the master toilet was gone. I flushed the toilet and the water completely ran out, although the tank emptied into the bowl. I then poured a bucket of water into the bowl, and it too drained completely out. I live in a first floor condo and none of my neighbors have had problems with their toilets, nor do I have a problem with the toilet in the guest bath. There is no water running onto the floor and I do not have any sewer odors in the bathroom. Does anyone know why the bowl will not hold water, as it worked fine before I left?
    5,789
    Default Re: Toilet bowl will not hold water
    Is it possible that the bowl froze while you were gone and cracked?
    Jan 2009
    iowa
    11
    if there is no water leeking the only other explaination is how the drain is plumbed in , if the drain coming from the toilet to the stack isnt vertical this can cause a syphoning effect that would drag all the water from the toilet trap ,its known as a "S"trap wich is illegal in most states
