    Jan 2009
    Default Loose Toilet Base
    There are two toilets that handicapped people use that continue to loosen at the base due to clients moving back and forth from their wheelchair to the toilets. How can I secure these toilets so they will not constantly loosen? Both bathroom areas already have hand grabs installed beside the toilets.
    6,047
    Default Re: Loose Toilet Base
    Had the same problem at my SIL's house. What I did was tighten down the toilet as normal the screwed 1 X 1 wood strips on each side, front and back right against the toilet base. Stopping the side movement seemed to solve the problem. You could get fancy and make the pieces so they match the outline of the toilet base.
