    Jan 2009
    Default Glue on Drywall?
    After removing 6 layers of wallpapperI was saddened by finding that one wall had glue streaks running up and down, the other people had something glued on that wall. I tried to sand them off to NO avail. I tried to use a razor blade but this was removing the protecting paper on the drywall. Any suggestions other than replacing some of the drywall?
    Dorene Junkin
    6,024
    Default Re: Glue on Drywall?
    2 suggestions.
    1] Skim-coat the wall, A lot of work and patience.
    2]Cover the glue with mud and feather it out just like you would a taped joint.
    After doing either 1 or 2 seal the new mud with PVA primer and 2 coats of KILZ before you paper again.
    Jan 2009
    Thank you! I assume I can do what you advised for painting also, as that is what I want to do? I will try feathering oveer the streaks...
