    Jan 2009
    Fort Hood, Texas
    Exclamation Basement Help: Dirt walls and floor
    any idea on the best way to seal a dirt basement. Nothings level nothings even . Was given the family home built by great grandfather. Needs some work.
    Eden, NC
    285
    Wink Re: Basement Help: Dirt walls and floor
    Have you considered a concrete floor and concrete block walls. Probably the most solid way to go (no pun intended)without future problems.
    Calcats
    1,387
    Default Re: Basement Help: Dirt walls and floor
    Howdy, do you use the basement? If not the $$$ spent gets more sealed. The easist is to put down 6 mil plastic but it will not hold up to foot traffic. A cement slab could be installed. Could have spray foam applied to dirt basement.
