    145
    Default electrical extension cord
    Can an electrical extension cord be used outdoors during rain
    storm to pump water from backyard. Backyard becomes flooded and water flows into basement. Who can I
    call for an evalution on how to fix this problem. Should I call a home inspector or a basement specalist or a landscaper for a diagnosis.
    Thank you
    6,063
    Default Re: electrical extension cord
    Generally speaking yes if it is a grounded cord and you keep the plugs from being submerged.
    I would suggest you check the grading first. It should be sloped away from the house and low spots filled.
