    Oct 2010
    Default Cleaning out old water lines
    A few years ago I heard of a device that will clean out old iron pipes and coat the inside with a Teflon type of substance. I am now in need, but can not remember the name of the tool or procedure. Does anyone know the name of the device/procedure?
    Nashville, TN
    148
    Default Re: Cleaning out old water lines
    This pipe re-liner is used for primarly sewer lines 4" or larger.
    Also, check out this articale in Plumbing & Mechanical magazine http://www.pmmag.com/Articles/Cover_...00f932a8c0____
    Perma-Liner and MaxLiner are both methods used.
    Process of elimination. Good luck.
