    Jan 2009
    Default Dryer plug receptacle replacement
    Hi I need to replace the receptacle that my dryer plug goes in. How do I do this please.
    Bob
    racwizard@yahoo.com
    Thanks
    5,941
    Default Re: Dryer plug receptacle replacement
    Turn off electricity, remove cover, pull receptacle, disconnect wires, get new receptacle, connect wires, install receptacle, install cover, turn on electricity.
    1,794
    In the event the wires are aluminum, be sure to use an antioxidant compound intended for aluminum electrical wires.
    You may find it easier to replace the cord on the dryer with one that fits the outlet.
    1,794
    Can you describe the wall outlet and the cord that's presently installed on the dryer? Does it have three prongs or four? Not counting any round prongs, is the center prong straight or L-shaped?
    Which of the following looks like your wall outlet? Which of the following would you plug the present dryer cord into? (Use the NEMA number to indicate that.)
    125/250V 30A:
    [IMG]http://www.stay******.com/images/products_240x240/4412.jpg[/IMG][IMG]http://www.stay******.com/images/products_240x240/1542.jpg[/IMG]
    125/250V 50A:
    [IMG]http://www.stay******.com/images/products_240x240/8539.jpg[/IMG][IMG]http://www.stay******.com/images/products_240x240/8694.jpg[/IMG]
