    Jan 2009
    Default Drywall over tiles
    Just signed up and making my first post. My house was built by Sears and Roebuck back in the late 30's. The ceilings in my living room, and dining room have 12"x 12" tiles on them held up with adhesive. Some of the tiles are coming loose and causing a section of the ceiling to sag. I'm thinking of putting up drywall over the tiles to save on time and mess. Would there be any problems with doing this? I plan on making sure the ceiling is flat, and marking the joists for the drywall screws.
    Thanks,
    Will
    Eden, NC
    285
    Wink Re: Drywall over tiles
    The way you have planned to do the job sounds ok. The only problem I can see is if you have any tile missing and you put your drywall screw in you pull the drywall up into a "divot" or crack the drywall.
    Calcats
    Jan 2009
    Default Re: Drywall over tiles
    Calcats,
    I plan on making sure all tiles are in place for just that reason. Thanks for the feedback.
    Will
