    Nov 2009
    14
    Default what color for crown molding
    What color do i paint the crown molding? the wall color the ceiling color or a neutral of both?
    1,522
    Default Re: what color for crown molding
    its all a matter of personal taste
    some people paint crown with the same paint as the rest of the trim, others do it with ceiling paint
    7,189
    I would change that to "ceiling color" rather than ceiling paint. Big difference. Other than that, you're right. I tend to go ceiling color in a semi-gloss finish.
    5,836
    If you paint it the color of the walls it will make the walls look taller and the size of the room appear slightly smaller. If you paint it the same color as the ceiling, that ceiling will appear lower, the walls shorter, and the room will appear slightly larger. A contrasting color generally boxes in the room.
    Oct 2010
    9 times outta a 10 paint grade molding is painted the same color as your existing trim, normally white
    Brian
    http://www.thefinishingcompany.net
