    Oct 2010
    Default Clogged Lavatory Drain
    My lavatory drain has a stubborn clog. Plunging did not help. I removed the underneath u-shaped pipe and inserted 7 1/2 feet of snake (as far as the snake will go). I can pull nothing out. What would be my next step?
    Default Re: Clogged Lavatory Drain
    Use a longer snake.
    6,115
    Remove the stopper mechanism and see if the stoppage is above the trap.
    Nashville, TN
    148
    Add water while using the snake as sometimes both help loosen up any debris or hair.
    Process of elimination. Good luck.
