Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Jan 2009
    5
    Default Re: tile over laminate counter tops?
    Well I did it and it turned out okay. It took longer than anticipated and after 4 days I was beat.
    Here are some pictures before, during and after.
  2. #12
    Jun 2011
    Quote Originally Posted by Sandiepiper View Post
    We tiled a bathroom countertop about a year ago. We bought a new sink which was just slightly smaller than the existing hole so after cutting out the sink hole in both a piece of plywood and cement backer board we mounted both on top of the existing laminate top using an adhesive and then screwed it all together. It was ready to tile the next day. The plywood and backer board make the countertop a bit higher than 'normal' which is a bit easier on the back. It was a pretty easy job and we will probably do the same thing in our other two bathrooms.
    I will try to add pics. Hope this helps.
    Is there a danger from moisture and water from putting screw holes in the backer board?
  3. #13
    Sep 2007
    Long Island, NY
    269
    Quote Originally Posted by Oldman View Post
    You "have to" fasten the boards together with CBU screws (or roofing nails but CBU screws are better imo). The adhesive should be a thinset rather than a mastic under the CBU as thinset is more waterproof and will level the boards better.
    Hidden Content
    ॐשָׁלו
  4. #14
    3,160
    Painting the surface of the CBU with a waterproofing membrane such as hydroban or redguard will waterproof the counter including the screw heads/holes
  5. #15
    Sep 2007
    Long Island, NY
    269
    you could cover it with Kerdi too...lol
    Hidden Content
    ॐשָׁלו
  6. #16
    Nov 2011
    7
    Great after pics!
