Results 1 to 8 of 8
Thread: Sue52
    Default Sue52
    I am trying to install chair railing (2 1/2") on wall going down a stair wall (no wainscotting). problen is wall is straight for 16" then angles down to follow line of stairs.I cannot figure out how to match the angle with the straight edge plus the chair rail has a pattern to it.Any help greatly appreciated befor I lose my mind thanks
    7,048
    Default Re: Sue52
    You determine the degree of angle change, say 45* for example, and divide by 2 which is 22.5*. You'd cut the end of each piece at 22.5*. Probably the easiest way to figure out the true angle would be to have a helper hold one uncut piece in place while you hold the other and mark the top and bottom of each piece where they overlap.
    Default Re: Sue52
    Hey sue - what you are describing is not like the average 45 or 22 1/2 degrees like you would expect - i would use a "sliding t-bevel to copy the exact angle and then transfer it to your miter saw - this will make it easier to find the angle (no need to know the exact angle quantity then) - have fun with the moulding
    Sep 2009
    florida
    598
    Default Re: Sue52
    This tool will find and give you the cuts needed. There should be a smaller 10"version of the tool being lanuched this week on Amazon.
    http://www.amazon.com/QUINT-GRAPHICS...4366483&sr=8-1
    Gizmo
    Hidden Content
    Hidden Content
    Sep 2009
    florida
    598
    Default Re: Sue52
    Sue52,The pictures I posted are just to give you an idea how to find your miter angle cuts with the MMP tool or any other brand tool.
    I placed the tool on an existing stair hand rail, its the same concept you will need with the chair railing.
    The 1st & 3rd pic's are at the botton & top of the stair. The 2nd and 4th are close ups indicating the desired saw setting in the reciprocal window of the tool.
    Good Luck
    Click image for larger version.
Name:	MMP Railing 1.jpg
    Gizmo
    Hidden Content
    Hidden Content
    1,522
    Default Re: Sue52
    what everyone has forgotten is the 1st step, layout the chair rail line on the wall first.
    detereming the height of it then make a level line on the walls where it will run level. bring this line over to the nosing of the top of the landing, then do the same at the lower floor, from there you need 2 people, snap a chalk line from these two points, these lines are what you will use to determine the angle from. from there use a angle finder and go at it
    i have attached a couple pics from a house i trimmed out a few years back with a similar detail
ID:	3850   Click image for larger version.
    Sep 2009
    florida
    598
    Default Re: Sue52
    Good point jkirk, I guess we all figured the layout was pretty much a common practice before anything else.
    Nice work by the way in the pics I see there are accute "Miter" angles that could really confuse a novice........
    Gizmo
    Hidden Content
    Hidden Content
    Sep 2009
    florida
    598
    Default Re: Sue52
    Quote Originally Posted by Gizmo View Post
    Good Luck
    The 10" Miter Master Plus was " Finally" just launched on Amazon.
    http://www.amazon.com/T110-MITER-MAS...4871316&sr=8-4
    Gizmo
    Hidden Content
    Hidden Content
