Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
  1. #21
    731
    Default Re: Cold clothes dryer
    Quote Originally Posted by havanagranite View Post
    you haven't proved anything other than being able to do cut and paste. your rude, obnoxious and have no useable knowledge. your only value would be the person in the carnival who works at the dunking booth insults people to get them to spend their money and you do the same here trying to get people to waste their time reading your 10 page posts. people don't want cut and paste messages nor that done on google search they could do that themselves. they want first hand experience which you don't have. you need to find a computer forum where you can put your skills to work, it isn't here and quite frankly I'm rather tired of seeing your sig at all. I'm sorry you were picked on so bad in school and that your husband left you. but that isn't our problem get over it.
    Oh so juvenile. simple minded one.
    Rubber, glue, bounces, sticks on you. Your intellect and insults not even at the level of a carny - but fits your personality perfectly.
    You are just a stalking, rude, harassing, flamer.
    NFPA 54 2002 Ed. Chap9, NFPA 54 2006, Chap 10. READ IT.
    Manufacturer's listed installation instructions: READ THEM.
    Specifications for venting materials, READ THEM.
    But then again IF you could READ THEM, you'd also have to be able to UNDERSTAND THEM. Both, obviously, beyond your capabilities.
    Your gang is the only ones who use or speak of google. You can't even keep your insults and lies straight.
  2. #22
    980
    what you are quoting says rigid vent, aluminum vent is a rigid vent it isn't only made in a flex.
    http://www.northlineexpress.com/item...p?ic=5CO-89600
    but YOU would have to understand what you cut and paste and that would mean you would have to have a basic knowledge. which you keep showing you don't
  3. #23
    Once again Blue Ridge has reduced another thread down to a sounding board for herself.
    The OP had stated his dryer setup .... that Blue Ridge has condemed ..... is done to code.
    However according to Blue Ridge's supposed knowledge and experience this can't be so.
    Blue Ridge whatever you may believe ...... things will get approved and and codes will be met without your involvement or blessing .
    Oh .... I am licensed to drive.
  4. #24
    731
    you do realize that there is an aluminum rigid duct? not just aluminum flex?
    Quote Originally Posted by Blue RidgeParkway View Post
    Sure do. And in many cases either model codes, listings, manufacturer's instructions, locally drafted codes, and local ammendments prohibit or restrict its use for venting GAS clothes dryers, non-condensing type (most especially if in contact with or within a certain proximity to: mortar, masonry, "concrete", "cement", etc.).
    rigid aluminum is what you will find in most new construction in homes for venting of dryers regardless of elec or gas.
    Nope and your saying that is some sort of fact doesn't make it so.
    I acknowledged aluminum rigid vent pipe way back. Still shouldn't be used in basement or masonry wall penetrations as indicated. Semi-rigid is not permitted by the National Fuel Gas Code to be used for GAS clothes dryers.
    Aluminum HEAVY walled rigid dryer venting for electric is common. for GAS is NOT recommended for venting near grade or via masonry or concrete for gas clothes dryers. THIN walled aluminum duct is NOT recommended for either gas or electric clothes dryers. The Standard is based on heavy walled galvanized steel. Stainless Steel is next. Heavy walled aluminum has a limited application.
    There is a reason the codes have changed, one of them has been continued home fires, another moisture, mold, rot problems in homes - both issues contributed to by ineffecient venting of the gas clothes drier. As we strive to be more energy efficient and make our homes more comfortable, draft free, etc. we learn that other things are effected - this is one of those areas. This is really not old news - discussion on this issue goes back to the late 80s and early 90s code cycles changes have occured with every code cycle of every model code.
  5. #25
    731
    If the original poster's gas clothes dryer venting situation was correct would not be having UPDRAFTS of cold to first floor laundry area where venting was down inside wall under floor in unconditioned basement space and out through outside wall.
  6. #26
    980
    and you would know this based on your experience in doing what? how can you say it will or won't do something if your only experience is google. it isn't logical......or wait I guess that kind of says it doesn't it
  7. #27
    731
    None of YOUR buisness!! Yeah, that's just the right thing to do, tell a warped, harassing, lying, stalker like you or your gang, right! Internet safety 101.
    Plus if you knew you're head would probably explode and your other tiny parts might wither and fall off.
  8. #28
    980
    you have already stated you didn't have experience that your knowledge was only from google.
  9. #29
    Of course .... if it was done to code the ducting used would be directional .... the arrows would pointing toward the exterior.
  10. #30
    LOL
    Well .... we know you're not an electrician .... as stated by yourself.
