Thread: beadboard
    Default beadboard
    Can I glue bead board over bathroom tile
    7,191
    Default Re: beadboard
    Probably, but I wouldn't recommend it.
    1,522
    there's no guarentee that the glue alone will hold the beadboard, a mechaical fastener should be used be it a from a finish nailer or hand nailing
    what type are you using, mdf? if you do be sure to hit it with a coat of oil based primer first on all 4 sides and the ends to seal it from absorbing moisture
