    Jan 2009
    Default Help identifying closet storage system
    I have a white melamine closet storage system. I need some more components to do a reconfiguration. I have not been able to identify the particular system ****** or in the local stores. The side panels use a metal fastener system to attach to a back wall bracket. The fastener has screw adjustments to tighten to the bracket and do some vertical adjustment. I have attached a picture of the fastener and the wall bracket.
    Any info would be appreciated.
    Thank you.
ID:	1964   Click image for larger version.
    Sep 2009
    Default Re: Help identifying closet storage system
    Both are common hardware items in the closet industry. I would first try your local California Closets, or call around to other local closet companies and ask if they're using a 'hanging' system.
    If so, they might sell you the parts you need to complete your closet.
    Good luck!
