Results 1 to 8 of 8
    Jan 2009
    Default What is this tool?
    I found this tool in my old house, what is it? I have searched all over google for info on it. Any help?
    6,115
    Default Re: What is this tool?
    Might be and old awning crank. At least part of one.
    Geez .... that's what I thinking as well .... Oh Oh ... starting to show our age Jack.
    Definately looks to be part of a crank mechanisim.
    1,131
    Starting to show your age,eh?
    I'll go ya one better.
    It looks to me like it could also be the hand-crank for an old car or tractor engine.
    731
    Looks to me to be a crank axis for an end-over-end type barrel churn (for making butter from cream) which rotated the barrel end over end while half-filled and mounted on a shaft/crank.
    Although it could be a long axis barrel churn crank (a dasher paddle probably wood) slipped on the shaft when loading the barrel this type, like a box churn, the barrel or box did not turn just the dasher. Both churn types are revolving type churns.
    Some examples (first three are end-over-end and don't use dasher or padle).:
Name:	barrel churn metal.jpg
ID:	1972   Click image for larger version.
Name:	barrel churn.jpg
ID:	1973   Click image for larger version.
Name:	barrel churn3.jpg
ID:	1974   Click image for larger version.
Name:	barrel churn2.jpg
    731
    I remember awning "cranks" looking more like a brace and functioning similarly, like this:
Name:	awning drill brace crank.jpg
    1,131
    6,115
    Quote Originally Posted by ****hiller View Post
    Never seen an auto or tractor crank with a wood handle and wood slip handle. Try to use a slip handle on an auto crank and you would end up loosing something.
    The old awning cranks were generally jointed so the could be folded in half when not in use. You held the slip handle in one hand and cranked with the other.
