    Jan 2009
    Exclamation Replace the clean out plug in a cast pipe
    I need to replace the clean out plug in the cast pipe (sewer line) which is just above the concrete floor in my basement. My house was built in 1946 and bell type pipe 5" in length was used and it seems to be sealed with lead. My questions is: what is the best way to remove this clean out plug (removing the lead) so I can add a new piece of pvc in it's place???
    1,906
    Default Re: Replace the clean out plug in a cast pipe
    Are you sure that it's not a threaded plug screwed into an insert, and it's the insert that's set in lead? If you can unscrew it, just use a male threaded adapter to the plastic pipe.
    Jan 2009
    Thanks for responding, I do need to replace the actual insert.
    Any ideas on removing the lead? drill into it and then chip it out?
